I just noticed that something apparently changed in the last
version for the batch processing - I try to run the same (let's better
say a similar) script for batch processing as I did last November using
version 2.0.3 (I think) - now I get:
----WARNING--- Loading signal ...----
Unknown format for ost-00-batch-fk-28012009.log
geopsy: no signal available, check options -file, -db or -group, see -h for help
I think the error message startgin from "geopsy:" is not indicative - what
might have change in the code is some different or stricter
checking of the parameter file? I attach the parameter file below
hmm can't upload the file
- well let me know if you need the file for analysis
read u
Matthias
