Passive MASW processing
Aniket19061990
Post by Aniket19061990 »
Hi.
I have recorded data (velocity time histories) using a circular and an L-shaped array in passive MASW testing. I want to process it using SPAC and fk method and generate dispersion curve. i seached for tutorials on the website and youtube videos and followed whatever I found. Still, there were some issues in doing what is shown. It may be due to the fact that the tutorials are for older versions of Geopsy. I request you to provide a step by step tutorial on how to process the passive MASW data and generate a dispersion curve. In fact, a video tutorial is required because what I found on the webpage (https://www.geopsy.org/wiki/index.php/MSPAC) did not work for me.
Re: Passive MASW processing
Can you show me exactly what does not work for you following this tutorial? With your data or with the provided dataset. This tutorial is not fully up-to-date, but it is still valid except for some minor details. I'll try to revise it whenever I have a bit of time.
