I would like to represent the HVSR time histories.
Is it possible to do this with Geopsy?
HVSR time histories
Re: HVSR time histories
Not directly. H/V can be computed with a script running geopsy-hv, and results can be plotted externally. I think that there was post about that somewhere on the forum. Try a search with "geopsy-hv".
I found only one post, scrolling the list because the keywords suggested for the search are considered too generic. The post is 207 and your reply (year 2012) was a commitment to implement this utility in the next releases ("Currently not, but it is an option we will certainly implement in a close future")...
Is there a way to calculate the H/V curves at discrete time intervals so that they can be plotted with other software? With geopsy-hv -h I haven't found any way that leads to this result.
Best Regards
Best Regards
Here is the post I was referring to:
viewtopic.php?t=504
Effectively, the search engine provided by the forum does not accept a search for "geopsy-hv". You have to go to your favourite search engine and type (DuckDuckGo, google,...):
It restricts the search to geopsy website. The search field at the top of the page does normally that operation, but apparently it does not work any more.
viewtopic.php?t=504
site:geopsy.org forum "geopsy-hv"Re: HVSR time histories
The search field at the top of the page is now fixed. This is was an issue only within the forum.
