problem with Frequency domain window rejection (Cox et al. (2020, GJI)
victoriafc
Post by victoriafc »
Hello, i'm using H/V in geopsy.
I don't know how to disable the Frequency domain window rejection (Cox et al. (2020, GJI) in the time windows ->select.
I used it one time and now every time that I run the programan in the *.log appear
# Frequency domain window rejection (Cox et al. (2020, GJI)
FREQUENCY_WINDOW_REJECTION_MINIMUM_FREQUENCY=0.0001
FREQUENCY_WINDOW_REJECTION_MAXIMUM_FREQUENCY=5000
FREQUENCY_WINDOW_REJECTION_STDDEV_FACTOR=2
FREQUENCY_WINDOW_REJECTION_MAXIMUM_ITERATIONS=50
I hope anyone can help me!
Re: problem with Frequency domain window rejection (Cox et al. (2020, GJI)
These parameters are defined but not used unless you run "Select/Frequency rejection".
Hi victoriafc,
if you are interested in learning more about this utility and its setting go to the post viewtopic.php?t=535 where there is a concise but exhaustive explanation by Brady Cox following my question.
I hope it can be useful to you
