Inversion using dinver
nroy1deq
Post by nroy1deq »
I want to select all the dispersion curves/ vs profiles below a particular misfit value after inversion. I am using MSYS. Now when I am exporting results to a .txt file below a max misfit 0.2200 (min misfit= 0.0075), it is appearing the .txt file is unable to store all (nearly 80,000) the dispersion curves/ vs profiles. Is there any limitation of size that a .txt file can store. What are the other ways so that I can export 80,000 to 1,00,000 dispersion curves/ vs profiles. Please help.
nroy1deq
Re: Inversion using dinver
Post by nroy1deq »
It is also appearing that whenever I am selecting profiles with a max misfit 0.1, 0.15, 0.2 etc., in all cases I am getting a total no of profiles 32,767. But logically no of profiles with Max misfit 0.2 should be higher than no of profiles with a max misfit of 0.1.
I am quite consfused, please help.
