Hello admin,
I'm working as researcher at Istituto Nazionale di Geofisica e Vulcanologia Roma, Italy, and I deal of site effects.
This is my problem during installation:
I configure script, when done I install geopsypack (make install)
This is the error:
src/AbstractStream.h: In member function ‘QGpCoreTools::AbstractStream& QGpCoreTools::AbstractStream::operator<<(char)’:
src/AbstractStream.h:59:69: error: ‘fromAscii’ is not a member of ‘QChar’
AbstractStream& operator<<(char val) {return operator<<(QString(QChar::fromAscii(val)));}
Do you have any suggestion?
thanks
Installation problems
Re: Installation problems
I'm not sure it will solve the problem, but check your version of the QT libraries. It should be 4.6.3 or greater.
Luciana Cantore
Qt version is 4.8.1
Please try to open the file "AbstractStream.h" in the folder "/QGpCoreTools/src" and replace "fromAscii" with "fromLatin1" at the line 59.
Luciana Cantore
I tried your suggestion, but I have a new error message:
make[2]: ingresso nella directory "/home/luciana/Scrivania/geopsypack-57items-src-2.4.4/QGpCoreTools"
g++ -c -m64 -pipe -O2 -Wall -W -D_REENTRANT -fPIC -DMAKE_QGPCORETOOLS_DLL -DQT_NO_DEBUG -DQT_CORE_LIB -I/usr/share/qt5/mkspecs/linux-g++-64 -I. -Isrc -Iui -I../include -I/usr/include/qt5 -I/usr/include/qt5/QtCore -Irelease -o release/Cache.o src/Cache.cpp
src/Cache.cpp: In member function ‘bool QGpCoreTools::Cache::makeAvailable(const QGpCoreTools::CacheItem*)’:
src/Cache.cpp:199:65: error: ‘class QString’ has no member named ‘toAscii’
CoreApplication::instance()->reportBug( Message::Warning, msg.toAscii().data() );
src/Cache.cpp: In member function ‘bool QGpCoreTools::Cache::enlarge(QGpCoreTools::CacheItem*, double)’:
src/Cache.cpp:226:69: error: ‘class QString’ has no member named ‘toAscii’
make[2]: *** [release/Cache.o] Errore 1
make[2]: uscita dalla directory "/home/luciana/Scrivania/geopsypack-57items-src-2.4.4/QGpCoreTools"
make[1]: *** [release-install] Errore 2
make[1]: uscita dalla directory "/home/luciana/Scrivania/geopsypack-57items-src-2.4.4/QGpCoreTools"
make: *** [sub-QGpCoreTools-install_subtargets-ordered] Errore 2
Do you have any suggestions?
Cheers, Luciana
Cheers, Luciana
Same error, at lines 199 and 226 of the file "Cache.cpp".
I have to warn you that I'm actually not an expert of Qt development and I can not guarantee that these edits are without side effects, although they seem safe (see here.)
If you are using Qt 5, you should try only the "devel" release. The current "testing" release supports only Qt4.
To check your Qt version, run:
$ qmake -v
QMake version 2.01a
Using Qt version 4.8.6 in /usr/lib64/qt4
