New masw problem with Geopsy releases above 3.0
Hi Marc, I'm working with Masw FK and after a first run where the FK results are correct for different time windows and offsets, the FK results no longer appear and the window remains empty without any error being highlighted in the message window, rather than the operation was completed.
I reloaded Geopsy 3.4.2 and also 3.3.6 having the foresight of clear the tools from Geopsyland, but to no avail. Obviously I tried with previous processed files too and and even with these it was not possible to obtain the FK spectrum.
Using an older version (2.10) the tool works.
This is the first time it has happened and I don't understand the reason.
What is your opinion?
thank you
(98.08 KiB) Not downloaded yet
Pourya
Re: New masw problem with Geopsy releases above 3.0
Post by Pourya »
Hi mark,
the same thing is happening to me. The F-K method is not showing the colored dispersion image. Any idea what could be wrong? It worked for me in the morning but suddenly it is not showing anything ( the log does not show any error).
(118.72 KiB) Not downloaded yet
I've no idea. I checked with 3.4.2 without being able to reproduce the problem. Can you check if the opacity of the layer with the FK results is at 1 (in graphic properties)? Can you copy the text of the complete log and post it here?
That's the first step. In a second step, I will ask you to send me a signal file, to further inquire about this issue.
Pourya
Post by Pourya »
Hi Mike,
The opacity is 1 as you can see in the attached screenshot. Also, it does not matter which file I am using, I do not get any results. Here is the complete log :
Loading C:/School/PhD/Geopsy/Analyze with Geopsy-Dr. Coe/EX1(completed)/1001.sg2...
wrong character: '.'
error parsing time 'h:m:sz'
ACQUISITION_TIME='1.000' is invalid
*********** (0.0 0.0 0.0) @ 23:22:50 ***********
Add signal id 1 to component Vertical of station 1001.sg2 at 0.00 0.00 0.00
Add signal id 2 to component Vertical of station 1001.sg2 at 1.00 0.00 0.00
Add signal id 3 to component Vertical of station 1001.sg2 at 2.00 0.00 0.00
Add signal id 4 to component Vertical of station 1001.sg2 at 3.00 0.00 0.00
Add signal id 5 to component Vertical of station 1001.sg2 at 4.00 0.00 0.00
Add signal id 6 to component Vertical of station 1001.sg2 at 5.00 0.00 0.00
Add signal id 7 to component Vertical of station 1001.sg2 at 6.00 0.00 0.00
Add signal id 8 to component Vertical of station 1001.sg2 at 7.00 0.00 0.00
Add signal id 9 to component Vertical of station 1001.sg2 at 8.00 0.00 0.00
Add signal id 10 to component Vertical of station 1001.sg2 at 9.00 0.00 0.00
Add signal id 11 to component Vertical of station 1001.sg2 at 10.00 0.00 0.00
Add signal id 12 to component Vertical of station 1001.sg2 at 11.00 0.00 0.00
Add signal id 13 to component Vertical of station 1001.sg2 at 12.00 0.00 0.00
Add signal id 14 to component Vertical of station 1001.sg2 at 13.00 0.00 0.00
Add signal id 15 to component Vertical of station 1001.sg2 at 14.00 0.00 0.00
Add signal id 16 to component Vertical of station 1001.sg2 at 15.00 0.00 0.00
Add signal id 17 to component Vertical of station 1001.sg2 at 16.00 0.00 0.00
Add signal id 18 to component Vertical of station 1001.sg2 at 17.00 0.00 0.00
Add signal id 19 to component Vertical of station 1001.sg2 at 18.00 0.00 0.00
Add signal id 20 to component Vertical of station 1001.sg2 at 19.00 0.00 0.00
Add signal id 21 to component Vertical of station 1001.sg2 at 20.00 0.00 0.00
Add signal id 22 to component Vertical of station 1001.sg2 at 21.00 0.00 0.00
Add signal id 23 to component Vertical of station 1001.sg2 at 22.00 0.00 0.00
Add signal id 24 to component Vertical of station 1001.sg2 at 23.00 0.00 0.00
Add signal id 25 to component Vertical of station 1001.sg2 at 24.00 0.00 0.00
Add signal id 26 to component Vertical of station 1001.sg2 at 25.00 0.00 0.00
Add signal id 27 to component Vertical of station 1001.sg2 at 26.00 0.00 0.00
Add signal id 28 to component Vertical of station 1001.sg2 at 27.00 0.00 0.00
Add signal id 29 to component Vertical of station 1001.sg2 at 28.00 0.00 0.00
Add signal id 30 to component Vertical of station 1001.sg2 at 29.00 0.00 0.00
Add signal id 31 to component Vertical of station 1001.sg2 at 30.00 0.00 0.00
Add signal id 32 to component Vertical of station 1001.sg2 at 31.00 0.00 0.00
Add signal id 33 to component Vertical of station 1001.sg2 at 32.00 0.00 0.00
Add signal id 34 to component Vertical of station 1001.sg2 at 33.00 0.00 0.00
Add signal id 35 to component Vertical of station 1001.sg2 at 34.00 0.00 0.00
Add signal id 36 to component Vertical of station 1001.sg2 at 35.00 0.00 0.00
Add signal id 37 to component Vertical of station 1001.sg2 at 36.00 0.00 0.00
Add signal id 38 to component Vertical of station 1001.sg2 at 37.00 0.00 0.00
Add signal id 39 to component Vertical of station 1001.sg2 at 38.00 0.00 0.00
Add signal id 40 to component Vertical of station 1001.sg2 at 39.00 0.00 0.00
Add signal id 41 to component Vertical of station 1001.sg2 at 40.00 0.00 0.00
Add signal id 42 to component Vertical of station 1001.sg2 at 41.00 0.00 0.00
Add signal id 43 to component Vertical of station 1001.sg2 at 42.00 0.00 0.00
Add signal id 44 to component Vertical of station 1001.sg2 at 43.00 0.00 0.00
Add signal id 45 to component Vertical of station 1001.sg2 at 44.00 0.00 0.00
Add signal id 46 to component Vertical of station 1001.sg2 at 45.00 0.00 0.00
Add signal id 47 to component Vertical of station 1001.sg2 at 46.00 0.00 0.00
Add signal id 48 to component Vertical of station 1001.sg2 at 47.00 0.00 0.00
Relative coordinates with reference at (23.50 0.00).
Found 48 distinct stations (local coordinates):
-23.50 0.00 1001.sg2
-22.50 0.00 1001.sg2
-21.50 0.00 1001.sg2
-20.50 0.00 1001.sg2
-19.50 0.00 1001.sg2
-18.50 0.00 1001.sg2
-17.50 0.00 1001.sg2
-16.50 0.00 1001.sg2
-15.50 0.00 1001.sg2
-14.50 0.00 1001.sg2
-13.50 0.00 1001.sg2
-12.50 0.00 1001.sg2
-11.50 0.00 1001.sg2
-10.50 0.00 1001.sg2
-9.50 0.00 1001.sg2
-8.50 0.00 1001.sg2
-7.50 0.00 1001.sg2
-6.50 0.00 1001.sg2
-5.50 0.00 1001.sg2
-4.50 0.00 1001.sg2
-3.50 0.00 1001.sg2
-2.50 0.00 1001.sg2
-1.50 0.00 1001.sg2
-0.50 0.00 1001.sg2
0.50 0.00 1001.sg2
1.50 0.00 1001.sg2
2.50 0.00 1001.sg2
3.50 0.00 1001.sg2
4.50 0.00 1001.sg2
5.50 0.00 1001.sg2
6.50 0.00 1001.sg2
7.50 0.00 1001.sg2
8.50 0.00 1001.sg2
9.50 0.00 1001.sg2
10.50 0.00 1001.sg2
11.50 0.00 1001.sg2
12.50 0.00 1001.sg2
13.50 0.00 1001.sg2
14.50 0.00 1001.sg2
15.50 0.00 1001.sg2
16.50 0.00 1001.sg2
17.50 0.00 1001.sg2
18.50 0.00 1001.sg2
19.50 0.00 1001.sg2
20.50 0.00 1001.sg2
21.50 0.00 1001.sg2
22.50 0.00 1001.sg2
23.50 0.00 1001.sg2
-9.50 0.00 1001.sg2
-8.50 0.00 1001.sg2
-7.50 0.00 1001.sg2
-6.50 0.00 1001.sg2
-5.50 0.00 1001.sg2
-4.50 0.00 1001.sg2
-3.50 0.00 1001.sg2
-2.50 0.00 1001.sg2
-1.50 0.00 1001.sg2
-0.50 0.00 1001.sg2
0.50 0.00 1001.sg2
1.50 0.00 1001.sg2
2.50 0.00 1001.sg2
3.50 0.00 1001.sg2
4.50 0.00 1001.sg2
5.50 0.00 1001.sg2
6.50 0.00 1001.sg2
7.50 0.00 1001.sg2
8.50 0.00 1001.sg2
9.50 0.00 1001.sg2
10.50 0.00 1001.sg2
11.50 0.00 1001.sg2
12.50 0.00 1001.sg2
13.50 0.00 1001.sg2
14.50 0.00 1001.sg2
15.50 0.00 1001.sg2
16.50 0.00 1001.sg2
17.50 0.00 1001.sg2
18.50 0.00 1001.sg2
19.50 0.00 1001.sg2
20.50 0.00 1001.sg2
21.50 0.00 1001.sg2
22.50 0.00 1001.sg2
23.50 0.00 1001.sg2
[PARAM] # Version 0: all files generated with releases before 20170901 (default for input)
[PARAM] PARAMETERS_VERSION=1
[PARAM] # TYPEs:
[PARAM] # - Signal: from the start or to the end of signal (TEXT are useless)
[PARAM] # - Delta: a fixed duration counted from the start or the end (e.g. TEXT=1h).
[PARAM] # - Pick: from or to a time pick (TEXT=time pick name).
[PARAM] # - Absolute: from or to a fixed time (e.g. TEXT=20170314115338.00)
[PARAM] FROM_TIME_TYPE=Signal
[PARAM] FROM_TIME_TEXT=0s
[PARAM] # TYPEs: Signal, Delta, Absolute
[PARAM] TO_TIME_TYPE=Signal
[PARAM] TO_TIME_TEXT=0s
[PARAM] REFERENCE=
[PARAM] # TYPEs: Exactly, AtLeast, FrequencyDependent
[PARAM] WINDOW_LENGTH_TYPE=Exactly
[PARAM] WINDOW_MIN_LENGTH(s)=2
[PARAM] WINDOW_MAX_LENGTH(s)=2
[PARAM] WINDOW_MAX_COUNT=0
[PARAM] # Length of time windows are adjusted to avoid a prime number of samples which
[PARAM] # slows down the FFT computation. Usually a maximum prime 11 in the prime factorization
[PARAM] # of the number of samples is a good compromise between the speed and the lenght inaccuracy
[PARAM] # Leave as zero to allow any prime number factorization.
[PARAM] WINDOW_MAXIMUM_PRIME_FACTOR=11
[PARAM] BAD_SAMPLE_TOLERANCE (s)=0
[PARAM] BAD_SAMPLE_GAP (s)=0
[PARAM] WINDOW_OVERLAP (%)=0
[PARAM] # TYPEs: NoSampleThreshold, RelativeSampleThreshold, AbsoluteSampleThreshold
[PARAM] BAD_SAMPLE_THRESHOLD_TYPE=NoSampleThreshold
[PARAM] ANTI-TRIGGERING_ON_RAW_SIGNAL (y/n)=n
[PARAM] ANTI-TRIGGERING_ON_FILTERED_SIGNAL (y/n)=n
[PARAM] # Start a time window for each seismic event available inside the time range.
[PARAM] SEISMIC_EVENT_TRIGGER (y/n)=y
[PARAM] SEISMIC_EVENT_DELAY (s)=0
[PARAM] MINIMUM_FREQUENCY=5
[PARAM] MAXIMUM_FREQUENCY=110
[PARAM] # Either 'Linear', 'Log' or 'Inversed'
[PARAM] SCALE_TYPE_FREQUENCY=Log
[PARAM] # Number of samples is either set to a fixed value ('Count') or through a step between samples ('Step')'
[PARAM] STEP_TYPE_FREQUENCY=Step
[PARAM] SAMPLES_NUMBER_FREQUENCY=125
[PARAM] # STEP=difference between two successive samples for 'linear' scales
[PARAM] # STEP=ratio between two successive samples for 'log' scales
[PARAM] # STEP=difference between two successive inversed samples for 'inversed' scales
[PARAM] STEP_FREQUENCY=1.02504
[PARAM] # Overlap is controled by the WINDOWS parameters, by default non overlapping blocks are selected
[PARAM] BLOCK_OVERLAP(y/n)=n
[PARAM] # If BLOCK_COUNT is null, BLOCK_COUNT=BLOCK_COUNT_FACTOR*<number of stations>
[PARAM] BLOCK_COUNT=1
[PARAM] BLOCK_COUNT_FACTOR=4
[PARAM] # If STATISTIC_COUNT is not null, approx. STATISTIC_COUNT estimates par frequency
[PARAM] STATISTIC_COUNT=50
[PARAM] # If STATISTIC_MAX_OVERLAP=100%, successive statistics can be computed on overlapping block sets
[PARAM] # If STATISTIC_MAX_OVERLAP=0%, successive statistics are computed on non-overlapping block sets
[PARAM] STATISTIC_MAX_OVERLAP(%)=0
[PARAM] TAPER_WINDOW_TYPE=Tukey
[PARAM] TAPER_WINDOW_REVERSED=n
[PARAM] TAPER_WINDOW_ALPHA=0.2
[PARAM] # Gaussian band width from f*(1-bw) to f*(1+bw), f*bw=stddev
[PARAM] FREQ_BAND_WIDTH=0.05
[PARAM] # Required when using short and fixed length time windows, avoid classical oblique lines visible in the results
[PARAM] # when the number of frequency samples is higher than the number of points in the spectra.
[PARAM] OVER_SAMPLING_FACTOR=4
[PARAM] # A station is selected for processing only if it is available over a duration greater or equal to
[PARAM] # SELECT_DURATION_FACTOR*[total required duration]. The factor can vary from 0 to 1
[PARAM] SELECT_DURATION_FACTOR=0
[PARAM] # A station is selected for processing only if it is located at less than SELECT_ARRAY_RADIUS
[PARAM] # from SELECT_ARRAY_CENTER. SELECT_ARRAY_CENTER is the X, Y coordinates of the center.
[PARAM] SELECT_ARRAY_CENTER=0 0
[PARAM] SELECT_ARRAY_RADIUS=0
[PARAM] # Assuming that the north of sensors is aligned to the magnetic north and sensor coordinates to UTM grid,
[PARAM] # relative coordinates between stations are calculated with a correction for the difference between the
[PARAM] # geographical and the local UTM norths and for the magnetic declination. The later can be, for instance,
[PARAM] # calculated at https://www.ngdc.noaa.gov/geomag-web/#declination
[PARAM] # The value must be in degrees (positive for eastwards and negative for westwards).
[PARAM] MAGNETIC_DECLINATION=0
[PARAM] OUTPUT_BASE_NAME=
[PARAM] #
[PARAM] #
[PARAM] # FK method
[PARAM] #
[PARAM] #
[PARAM] # Process types:
[PARAM] # [Comp is the required components]
[PARAM] # Keyword Comp Comments
[PARAM] # Conventional Z Conventional FK processing.
[PARAM] # ConventionalRadial EN Conventional FK processing for radial projections.
[PARAM] # ConventionalTransverse EN Conventional FK processing for transverse projections.
[PARAM] # ConventionalRayleigh ENZ Conventional FK processing for radial projections.
[PARAM] # Capon Z High resolution FK processing (Capon, 1969).
[PARAM] # CaponRadial EN High resolution FK processing (Capon, 1969) for radial projections.
[PARAM] # CaponTransverse EN High resolution FK processing (Capon, 1969) for transverse projections.
[PARAM] # RTBF ENZ According to Wathelet et al (2018).
[PARAM] # Cross spectrum made of radial projections and vertical.
[PARAM] # Combined radial and vertical ellipticity steering.
[PARAM] # RTBFRadial ENZ According to Wathelet et al (2018).
[PARAM] # Radial ellipticity steering, better for small ellipticities.
[PARAM] # PoggiVertical ENZ According Poggi et al. (2010)
[PARAM] # k picked from vertical processing.
[PARAM] # PoggiRadial ENZ According Poggi et al. (2010)
[PARAM] # k picked from radial processing.
[PARAM] # RDS ENZ Rayleigh Direct Steering.
[PARAM] # Cross spectrum made of raw components E, N and Z.
[PARAM] # Radial projections included in the steering matrix.
[PARAM] # LDS EN Love Direct Steering.
[PARAM] # Cross spectrum made of raw components E and N.
[PARAM] # Transverse projections included in the steering matrix.
[PARAM] # RDSRadial ENZ Rayleigh Direct Steering.
[PARAM] # Experimental modes:
[PARAM] # RTBFFixedEll ENZ Same as RTBF but ellipticity is fixed.
[PARAM] # FIXED_ELLIPTICITY_FILE_NAME must be provided.
[PARAM] # RDSFixedEll ENZ Same as RDS but ellipticity is fixed.
[PARAM] # ActiveConventional Z Conventional FK processing for active sources.
[PARAM] # ActiveRTBF ENZ RTBF for active sources
[PARAM] # Cross spectrum made of radial and transverse projections.
[PARAM] # ActiveDS ENZ Cross spectrum made of raw components E, N and Z.
[PARAM] # Radial and transverse projections included in steering matrix.
[PARAM] # ActiveConventional Conventional FK processing for active sources
[PARAM] # Omni ENZ Same cross spectrum as RDS.
[PARAM] # Ouput power is the sum of power in all directions
[PARAM] # RDSVertical ENZ Cross spectrum made of raw components E, N and Z.
[PARAM] # Radial ellipticity steering.
[PARAM] # RDSRadial ENZ Cross spectrum made of raw components E, N and Z.
[PARAM] # Vertical ellipticity steering.
[PARAM] # RDSRefined ENZ Cross spectrum made of raw components E, N and Z.
[PARAM] # Iterative ellitpticity assessment.
[PARAM] PROCESS_TYPE=ActiveConventional
[PARAM] DAMPING_FACTOR=0
[PARAM] # If provided and PROCESS_TYPE==DirectSteering, the ellipticity is forced to the provided curve.
[PARAM] # The file must contain two columns: frequency and signed ellipticity.
[PARAM] # Provided sampling must not necessarily match the processing sampling frequency, linear interpolation is used.
[PARAM] # Better for precision if the two sampling match.
[PARAM] # To generate a synthetic curve: gpell M2.1.model -one-mode -R 1 -min 0.5 -max 50 -n 187 > curve.txt
[PARAM] FIXED_ELLIPTICITY_FILE_NAME=
[PARAM] # Minimum distance between source and receiver (for active source only)
[PARAM] MINIMUM_DISTANCE=1
[PARAM] # Maximum distance between source and receiver (for active source only)
[PARAM] MAXIMUM_DISTANCE=100
[PARAM] SOURCE_GRID_STEP=1
[PARAM] SOURCE_GRID_SIZE=0
[PARAM] # Experimental join processing of several arrays
[PARAM] # Several ARRAY can be defined with a list of station names
[PARAM] #
[PARAM] #
[PARAM] # Wavenumber grid
[PARAM] #
[PARAM] #
[PARAM] # Wavenumber fine gridding used as a cache for the FK maps
[PARAM] CACHE_GRID_STEP (rad/m)=0
[PARAM] # If CACHE_GRID_STEP is null, GRID_STEP is computed from K_MIN*CACHE_GRID_STEP_FACTOR.
[PARAM] CACHE_GRID_STEP_FACTOR=0.05
[PARAM] # Wavenumber coarse gridding used for searching maxima of the FK maps
[PARAM] GRID_STEP (rad/m)=0
[PARAM] # If GRID_STEP is null, GRID_STEP is computed from K_MIN*GRID_STEP_FACTOR.
[PARAM] GRID_STEP_FACTOR=0.1
[PARAM] GRID_SIZE (rad/m)=0
[PARAM] # If GRID_SIZE is null, GRID_SIZE is computed from K_MAX*GRID_SIZE_FACTOR.
[PARAM] GRID_SIZE_FACTOR=inf
[PARAM] # Effective GRID_STEP is 0.0136591.
[PARAM] # Effective GRID_SIZE is inf.
[PARAM] # Minimum velocity of the searched maxima of the FK map
[PARAM] MIN_V (m/s)=100
[PARAM] # Maximum velocity of the searched maxima of the FK map
[PARAM] MAX_V (m/s)=3500
[PARAM] # Minimum azimuth of the searched maxima of the FK map (clockwise from North)
[PARAM] MIN_AZIMUTH (deg.)=0
[PARAM] # Maximum azimith of the searched maxima of the FK map (clockwise from North)
[PARAM] MAX_AZIMUTH (deg.)=0
[PARAM] # Theoretical Kmin and Kmax computed from array geometry
[PARAM] # Used only for post-processing
[PARAM] K_MIN (rad/m)=0.136591
[PARAM] K_MAX (rad/m)=6.28319
[PARAM] #
[PARAM] #
[PARAM] # Peak picking
[PARAM] #
[PARAM] #
[PARAM] # Inversion method used for getting FK peaks: Gradient or RefinedGrid
[PARAM] INVERSION_METHOD=RefinedGrid
[PARAM] N_MAXIMA=2147483647
[PARAM] ABSOLUTE_THRESHOLD=0
[PARAM] RELATIVE_THRESHOLD (%)=0
[PARAM] SAVE_UNDEFINED_ELLIPTICITIES=n
[PARAM] EXPORT_ALL_FK_GRIDS=n
[PARAM] Y MINIMUM=100
[PARAM] Y MAXIMUM=1100
[PARAM] Y SCALE_TYPE=Log
[PARAM] Y STEP_TYPE=Step
[PARAM] Y SAMPLES_NUMBER=1
[PARAM] Y STEP=11
[PARAM] BEAM POWER NORMALIZATION=Maximum
[PARAM]
Process started at 2023-01-23 08:25:21
1/125 109.838 Hz, 1 windows (1.99998 s)
2/125 107.155 Hz, 1 windows (1.99998 s)
3/125 104.538 Hz, 1 windows (1.99998 s)
4/125 101.984 Hz, 1 windows (1.99998 s)
5/125 99.4927 Hz, 1 windows (1.99998 s)
7/125 94.6912 Hz, 1 windows (1.99998 s)
6/125 97.0623 Hz, 1 windows (1.99998 s)
8/125 92.3781 Hz, 1 windows (1.99998 s)
task index 3: processed during 0.112 s
9/125 90.1214 Hz, 1 windows (1.99998 s)
task index 6: processed during 0.115 s
task index 1: processed during 0.115 s
11/125 85.7722 Hz, 1 windows (1.99998 s)
10/125 87.9199 Hz, 1 windows (1.99998 s)
task index 7: processed during 0.12 s
12/125 83.6769 Hz, 1 windows (1.99998 s)
task index 4: processed during 0.121 s
task index 5: processed during 0.121 s
task index 2: processed during 0.121 s
13/125 81.6328 Hz, 1 windows (1.99998 s)
15/125 77.6932 Hz, 1 windows (1.99998 s)
14/125 79.6387 Hz, 1 windows (1.99998 s)
task index 0: processed during 0.126 s
16/125 75.7953 Hz, 1 windows (1.99998 s)
task index 9: processed during 0.104 s
17/125 73.9438 Hz, 1 windows (1.99998 s)
task index 8: processed during 0.108 s
18/125 72.1374 Hz, 1 windows (1.99998 s)
task index 10: processed during 0.107 s
19/125 70.3752 Hz, 1 windows (1.99998 s)
task index 12: processed during 0.107 s
task index 13: processed during 0.106 s
20/125 68.6561 Hz, 1 windows (1.99998 s)
task index 14: processed during 0.107 s
21/125 66.9789 Hz, 1 windows (1.99998 s)
22/125 65.3428 Hz, 1 windows (1.99998 s)
task index 11: processed during 0.118 s
23/125 63.7465 Hz, 1 windows (1.99998 s)
task index 15: processed during 0.115 s
24/125 62.1893 Hz, 1 windows (1.99998 s)
task index 17: processed during 0.104 s
25/125 60.6701 Hz, 1 windows (1.99998 s)
task index 16: processed during 0.109 s
26/125 59.1881 Hz, 1 windows (1.99998 s)
task index 21: processed during 0.104 s
task index 20: processed during 0.104 s
27/125 57.7422 Hz, 1 windows (1.99998 s)
28/125 56.3317 Hz, 1 windows (1.99998 s)
task index 19: processed during 0.105 s
task index 18: processed during 0.111 s
29/125 54.9556 Hz, 1 windows (1.99998 s)
30/125 53.6131 Hz, 1 windows (1.99998 s)
task index 23: processed during 0.108 s
task index 22: processed during 0.112 s
32/125 51.0257 Hz, 1 windows (1.99998 s)
31/125 52.3034 Hz, 1 windows (1.99998 s)
task index 24: processed during 0.108 s
33/125 49.7793 Hz, 1 windows (1.99998 s)
task index 25: processed during 0.108 s
task index 27: processed during 0.104 s
34/125 48.5632 Hz, 1 windows (1.99998 s)
task index 26: processed during 0.104 s
35/125 47.3769 Hz, 1 windows (1.99998 s)
36/125 46.2196 Hz, 1 windows (1.99998 s)
task index 28: processed during 0.113 s
37/125 45.0905 Hz, 1 windows (1.99998 s)
task index 29: processed during 0.122 s
38/125 43.989 Hz, 1 windows (1.99998 s)
task index 31: processed during 0.107 s
task index 30: processed during 0.107 s
39/125 42.9145 Hz, 1 windows (1.99998 s)
40/125 41.8661 Hz, 1 windows (1.99998 s)
task index 33: processed during 0.104 s
task index 34: processed during 0.104 s
41/125 40.8434 Hz, 1 windows (1.99998 s)
42/125 39.8457 Hz, 1 windows (1.99998 s)
task index 35: processed during 0.11 s
43/125 38.8723 Hz, 1 windows (1.99998 s)
task index 36: processed during 0.101 s
44/125 37.9227 Hz, 1 windows (1.99998 s)
task index 32: processed during 0.119 s
45/125 36.9963 Hz, 1 windows (1.99998 s)
task index 37: processed during 0.106 s
46/125 36.0926 Hz, 1 windows (1.99998 s)
task index 39: processed during 0.104 s
47/125 35.2109 Hz, 1 windows (1.99998 s)
task index 38: processed during 0.118 s
48/125 34.3508 Hz, 1 windows (1.99998 s)
task index 42: processed during 0.1 s
49/125 33.5116 Hz, 1 windows (1.99998 s)
task index 41: processed during 0.109 s
50/125 32.693 Hz, 1 windows (1.99998 s)
task index 40: processed during 0.113 s
51/125 31.8944 Hz, 1 windows (1.99998 s)
task index 44: processed during 0.108 s
52/125 31.1152 Hz, 1 windows (1.99998 s)
task index 43: processed during 0.116 s
53/125 30.3551 Hz, 1 windows (1.99998 s)
task index 46: processed during 0.105 s
54/125 29.6136 Hz, 1 windows (1.99998 s)
task index 45: processed during 0.11 s
55/125 28.8902 Hz, 1 windows (1.99998 s)
task index 47: processed during 0.108 s
56/125 28.1845 Hz, 1 windows (1.99998 s)
task index 48: processed during 0.103 s
57/125 27.496 Hz, 1 windows (1.99998 s)
task index 49: processed during 0.104 s
58/125 26.8243 Hz, 1 windows (1.99998 s)
task index 50: processed during 0.106 s
59/125 26.169 Hz, 1 windows (1.99998 s)
task index 51: processed during 0.107 s
60/125 25.5297 Hz, 1 windows (1.99998 s)
task index 52: processed during 0.104 s
61/125 24.9061 Hz, 1 windows (1.99998 s)
task index 53: processed during 0.106 s
62/125 24.2977 Hz, 1 windows (1.99998 s)
task index 54: processed during 0.108 s
63/125 23.7041 Hz, 1 windows (1.99998 s)
task index 55: processed during 0.108 s
64/125 23.1251 Hz, 1 windows (1.99998 s)
task index 56: processed during 0.109 s
65/125 22.5602 Hz, 1 windows (1.99998 s)
task index 58: processed during 0.102 s
66/125 22.0091 Hz, 1 windows (1.99998 s)
task index 57: processed during 0.111 s
67/125 21.4714 Hz, 1 windows (1.99998 s)
task index 60: processed during 0.105 s
68/125 20.9469 Hz, 1 windows (1.99998 s)
task index 59: processed during 0.109 s
69/125 20.4352 Hz, 1 windows (1.99998 s)
task index 61: processed during 0.107 s
70/125 19.936 Hz, 1 windows (1.99998 s)
task index 62: processed during 0.109 s
71/125 19.449 Hz, 1 windows (1.99998 s)
task index 63: processed during 0.105 s
72/125 18.9739 Hz, 1 windows (1.99998 s)
task index 65: processed during 0.103 s
73/125 18.5104 Hz, 1 windows (1.99998 s)
task index 66: processed during 0.103 s
task index 64: processed during 0.113 s
74/125 18.0582 Hz, 1 windows (1.99998 s)
75/125 17.6171 Hz, 1 windows (1.99998 s)
task index 67: processed during 0.105 s
76/125 17.1867 Hz, 1 windows (1.99998 s)
task index 68: processed during 0.106 s
77/125 16.7669 Hz, 1 windows (1.99998 s)
task index 69: processed during 0.103 s
78/125 16.3573 Hz, 1 windows (1.99998 s)
task index 70: processed during 0.101 s
79/125 15.9577 Hz, 1 windows (1.99998 s)
task index 71: processed during 0.102 s
80/125 15.5679 Hz, 1 windows (1.99998 s)
task index 72: processed during 0.101 s
task index 76: processed during 0.094 s
task index 74: processed during 0.106 s
task index 73: processed during 0.107 s
task index 78: processed during 0.092 s
task index 75: processed during 0.107 s
task index 77: processed during 0.1 s
task index 79: processed during 0.09 s
82/125 14.8166 Hz, 1 windows (1.99998 s)
87/125 13.0932 Hz, 1 windows (1.99998 s)
85/125 13.7571 Hz, 1 windows (1.99998 s)
84/125 14.1016 Hz, 1 windows (1.99998 s)
88/125 12.7733 Hz, 1 windows (1.99998 s)
83/125 14.4547 Hz, 1 windows (1.99998 s)
81/125 15.1876 Hz, 1 windows (1.99998 s)
86/125 13.421 Hz, 1 windows (1.99998 s)
task index 84: processed during 0.104 s
89/125 12.4613 Hz, 1 windows (1.99998 s)
task index 83: processed during 0.104 s
90/125 12.1569 Hz, 1 windows (1.99998 s)
task index 87: processed during 0.107 s
task index 82: processed during 0.107 s
task index 81: processed during 0.107 s
task index 86: processed during 0.108 s
92/125 11.5702 Hz, 1 windows (1.99998 s)
91/125 11.8599 Hz, 1 windows (1.99998 s)
94/125 11.0118 Hz, 1 windows (1.99998 s)
93/125 11.2876 Hz, 1 windows (1.99998 s)
task index 80: processed during 0.121 s
task index 85: processed during 0.121 s
95/125 10.7428 Hz, 1 windows (1.99998 s)
96/125 10.4804 Hz, 1 windows (1.99998 s)
task index 91: processed during 0.103 s
97/125 10.2244 Hz, 1 windows (1.99998 s)
task index 88: processed during 0.108 s
task index 93: processed during 0.103 s
98/125 9.9746 Hz, 1 windows (1.99998 s)
99/125 9.73094 Hz, 1 windows (1.99998 s)
task index 92: processed during 0.105 s
100/125 9.49323 Hz, 1 windows (1.99998 s)
task index 90: processed during 0.114 s
task index 95: processed during 0.1 s
101/125 9.26133 Hz, 1 windows (1.99998 s)
task index 89: processed during 0.118 s
102/125 9.03509 Hz, 1 windows (1.99998 s)
103/125 8.81438 Hz, 1 windows (1.99998 s)
task index 94: processed during 0.104 s
104/125 8.59906 Hz, 1 windows (1.99998 s)
task index 99: processed during 0.099 s
105/125 8.38899 Hz, 1 windows (1.99998 s)
task index 96: processed during 0.107 s
106/125 8.18407 Hz, 1 windows (1.99998 s)
task index 97: processed during 0.107 s
task index 98: processed during 0.107 s
107/125 7.98414 Hz, 1 windows (1.99998 s)
108/125 7.7891 Hz, 1 windows (1.99998 s)
task index 103: processed during 0.102 s
109/125 7.59883 Hz, 1 windows (1.99998 s)
task index 101: processed during 0.107 s
task index 102: processed during 0.106 s
110/125 7.4132 Hz, 1 windows (1.99998 s)
111/125 7.23211 Hz, 1 windows (1.99998 s)
task index 100: processed during 0.108 s
112/125 7.05544 Hz, 1 windows (1.99998 s)
task index 105: processed during 0.102 s
113/125 6.88309 Hz, 1 windows (1.99998 s)
task index 104: processed during 0.106 s
114/125 6.71495 Hz, 1 windows (1.99998 s)
task index 107: processed during 0.1 s
115/125 6.55091 Hz, 1 windows (1.99998 s)
task index 110: processed during 0.101 s
task index 108: processed during 0.103 s
116/125 6.39088 Hz, 1 windows (1.99998 s)
task index 111: processed during 0.098 s
117/125 6.23477 Hz, 1 windows (1.99998 s)
118/125 6.08246 Hz, 1 windows (1.99998 s)
task index 106: processed during 0.118 s
119/125 5.93388 Hz, 1 windows (1.99998 s)
task index 109: processed during 0.112 s
120/125 5.78892 Hz, 1 windows (1.99998 s)
task index 112: processed during 0.106 s
task index 113: processed during 0.107 s
task index 115: processed during 0.101 s
task index 114: processed during 0.11 s
task index 119: processed during 0.091 s
task index 117: processed during 0.101 s
task index 116: processed during 0.104 s
task index 118: processed during 0.102 s
124/125 5.24366 Hz, 1 windows (1.99998 s)
125/125 5.11557 Hz, 1 windows (1.99998 s)
122/125 5.50955 Hz, 1 windows (1.99998 s)
123/125 5.37496 Hz, 1 windows (1.99998 s)
121/125 5.64751 Hz, 1 windows (1.99998 s)
task index 120: processed during 0 s
task index 121: processed during 0 s
task index 122: processed during 0 s
task index 123: processed during 0 s
task index 124: processed during 0 s
Merging results...
Merging results...
Merging results...
task index 124: processed during 0.07 s
Merging results...
task index 121: processed during 0.073 s
Merging results...
task index 123: processed during 0.075 s
Merging results...
task index 122: processed during 0.082 s
Merging results...
task index 120: processed during 0.083 s
Merging results...
Process ended at 2023-01-23 08:25:23
Process run in 00:00:02
(312.4 KiB) Not downloaded yet
I think that I found the problem. Can you try to switch to "step count" for velocity sampling? The number of steps is probably 1. Set for instance 100. Is it better?
It occurs when switching to linear scale for velocity. After closing the tool and re-opening it, the number of samples is not properly initialized.
This is fixed for the next release (3.5.0).
Pourya
Post by Pourya »
Thank You Marc. You saved me :)--- It is working now.
after my post last year, the problem has not arisen again. After Pourya's post and your reply, I've verified that the step count is actually set to 100. If I set it to 1 the Active FK window remains empty.
Thanks for your returns. The next release is now more robust on this aspect. 3.5.0-preview is available from git (compilation required under Linux or Mac). Binaries for Windows will probably follow within a week or two.
