group selection in command line interface
sbonnefo
Post by sbonnefo »
I want to run fk processing using command line interface.
I use the following command:
geopsy -db database_name -tool geopsyarray -slot 0 -group "group_name" -param param_file
In this case, everything is fine.
However, if the selected group is located inside a directory (I mean in the groups list), then I am unable to run geopsy. I use this command:
geopsy -db database_name -tool geopsyarray -slot 0 -group "Directory/group_name" -param param_file
An error occurs: "unknown group of signals"
Any idea?
Sylvette
I checked with FK and got no problem of this kind.
My group is called: "333 sources/Array C/Vertical"
What's the group path you are looking for?
sbonnefo
Post by sbonnefo »
My group path is : "ARRAY 01/ARRAY01_Z"
Quite similar to yours ...
Maybe it is specific to Windows. I'll check tomorrow when I'll generate the new release.
