Inversion using dinver
Posted: Sat Jul 20, 2019 8:16 pm
I want to select all the dispersion curves/ vs profiles below a particular misfit value after inversion. I am using MSYS. Now when I am exporting results to a .txt file below a max misfit 0.2200 (min misfit= 0.0075), it is appearing the .txt file is unable to store all (nearly 80,000) the dispersion curves/ vs profiles. Is there any limitation of size that a .txt file can store. What are the other ways so that I can export 80,000 to 1,00,000 dispersion curves/ vs profiles. Please help.
