I was able to install an older version of geopsy (3.3.6) on my system: Apple M3 Max (Arm64) processor. I have compiled roughly following the infos on https://www.geopsy.org/wiki/index.php/I ... sy_package. I still use the x86-64 flag and install Rosetta. I use Qt5.14.2 version. The problem is that the app freezes when it starts. I am wondering if this is a problem of compatibility between the SDK and the QT version. when I use Qt6.7, unfortunately, I got an error.
In conclusion, I am bit lost and I was wondering if someone using Mac faced a similar problem. (I avoid to tell you how many things I tried..). Thank you.
installing geopsy from source on Mac (15.0 Sequoia)
Re: installing geopsy from source on Mac (15.0 Sequoia)
Did you try to start the application through a terminal? It might output useful information.
