Create Dinver parameters through command lines
Posted: Sat Sep 09, 2023 3:50 am
by Uki
I am using dinver to perform dispersion curve inversion.
Is it possible to create parameters (*.param) for input through command line?
Best ragards,
Uki
Re: Create Dinver parameters through command lines
Posted: Mon Dec 18, 2023 1:21 pm
by zibi
As far as I know, you can export the parametrization file from GUI and then call it from a command line as input for dinver.
I hope it helps.
Zibi
Posted: Thu Jan 04, 2024 7:28 pm
.param files are compressed xml files. They can be constructed manually. Zibi's suggestion is a good starting point. It is not necessary to compress the file, just set extension to .param.
Posted: Tue Jan 30, 2024 7:22 am
by Uki
Sorry for my delayed response.
I am grateful for you two's help.
Now I can edit the decompressed .param file.
Sincerely
Posted: Tue Nov 11, 2025 8:01 am
by iamjaisingh
Could you please elaborate on this? I did not understand completely.
