Damping and H/V
Posted: Wed Jan 11, 2023 5:16 pm
In a your work you used damping to prove that the H/V peak was natural. This is interesting because it adds to the "classic" satisfaction of the SESAME parameters to declare naturalness.
In the Geopsy documentation there are indications for setting the parameters (size of the window and suggestion of the order of the Butterworth filter), but the reality seems more complex to me. In fact, the value of z for the same data set appears directly proportional to the bandwidth of the bp filter and instead inversely proportional to the order of the Butterworth filter. Thus, when the z value is close to the 5% threshold, it would be enough to slightly modify one of these parameters to reach the goal of a z>5% value and thus "force" the conclusion of naturalness. Instead, using a frequency dependent filter I observed that the damping is almost always <5% whatever the window tape adopted.
So I ask if there are some criteria for a correct setting of the damping toolbox parameters.
