Harmonic Vs average profiles
Aniket19061990
Post by Aniket19061990 »
Hello.
I used the command in the format: gpdcreport file.report -best 100 | gpprofile -average-at 30 > out.txt.
The purpose was to get Vs30 for the top 100 Vs profiles with the lowest misfit. I used this also for other depths such as 5 m, 10 m and 20 m.
Now, what I want is Vs (average) profile up to bedrock depth, i.e., I wish that a profile with Vs (average) values sampled at each 1 m depth, up to the bedrock/ up to whatever depth we want. How can we get that? I request you to add some command to calculate it.
I have attached a figure explaining the Vs (average) profile.
(48.78 KiB) Not downloaded yet
Re: Harmonic Vs average profiles
If I correctly understood your request, this is implemented with option -average-depths
gpdcreport -best 100 my.report | gprofile -average-depths > out.txt
what if I wanted to set the depth to a certain value?
My ground profiles have a maximum depth of 32m, without bedrock, but average profiles (out.txt) are calculated with gpprofile (-average-depths) up to 100m. If I want to stop them at 30m, is there a command for that?
gpdcreport -best 100 my.report | gprofile -average-depths -max-depth 32 -n 32 > out.txt
Change N to have another sampling.
