gpviemax gphistogram R L
Posted: Tue Jun 29, 2021 12:46 pm
I have a question on the use of gpviemax or gphistogram of the new release 3.4.1, after a RTBF analysis performed on 3C passive data.
gpviemax produces always a result as in attach; I mean using no option, or using the option -R the output does not change (this is what I argue). The output in this example is with two well defined modes (I suppose Rayleigh) and the plot is distributed in 3 columns: the first column the two modes are together, and 2nd and 3rd the modes are separated. I cannot find more the option -L in gpviemax.
For gphistogram my comment is the same; it displays the results with the two modes but the option -L (and -R) seems no more present, or are probably with a different sintax
So if I am correct, my main question is:
How can I separate R and L contributions from the *max file after a RTBF 3c component using gpviemax or gphistogram?
Many thanks and my best
Giuseppe
Giuseppe
