Reliable Peak
Posted: Tue Jul 07, 2020 9:42 pm
when using the H/V method in Geopsy, is the selected peak frequency reliable based on SESAME guideline criteria? or we have to check those criteria ourselves to select a reliable peak? it seems that the amplitude (H/V value) of a reliable peak should be more than 2, which is not the case in the data I have (mostly around 1.3).
Thank you.
Thank you.
