geopsytfa and geopsy are separate or they are integated together in geopsy?
Posted: Tue Feb 02, 2016 9:39 am
by SivaramK
Dear Marc and Members of the team,
I am thankful to you all for providing this platform, for pointing out our problems of H/V and its Inversion.
I find that geopsypack has 55 items (when selected all) in version 2.9.0, showing separate pugin tools for geopsy and geopsytfa. However, there is no separate geopsytfa or hvtfa installed as mentioned in the documentation, but the installed geopsy has tfa incorporated in it.
However, the installed geopsy package of TFA does not show a window for storing of output i.e, .max files. Is this normal? I observe this in both linux and windows version.
Please help me, as this is required for H/V inversion.
Thanks and Regards
Sivaram K
Re: geopsytfa and geopsy are separate or they are integated together in geopsy?
Posted: Tue Apr 26, 2016 4:59 pm
Hi
HVTFA is not working properly on 'testing' release. You have to use the 'devel' release. There is a 'output directory' at the bottom of the toolbox. geopsytfa is a different plugin to compute time-frequency plots bases also on Morlet wavelet. Both components are plugins to geopsy. They are integrated in the graphical user interface or they can be uses in a command line. See geopsy -h all for all details.
Posted: Mon Jun 20, 2016 4:37 am
by SivaramK
Sorry for my late reply to your suggestion.
"There is a 'output directory' at the bottom of the toolbox."
But I don't find this output directory in the installed geopsy version 2.9.1.
Is something wrong? Can you suggest a way ahead to use the .max output from TFA for inversion in DINVER.
Thanks for any help.
Posted: Fri Jul 15, 2016 12:24 pm
by saeedsoltani
hi sivaram
I think you downloaded the wrong version, do you have the plugin that i mentioned with red circle in attachment?
when you use the hvtfa plugin you have a .max file in output directory that you will open it by max2curve plugin.
the max2curve output (tab:action --> save ) is suitable for inversion in dinver
Posted: Tue Jan 10, 2023 8:18 pm
by Pourya
Hi Mike,
I created a max file using HVTFA module but when i use max2curve, i get an which is attached. Any Idea why this is happening? I also used gpviewmax and I get error as well.
Posted: Thu Jan 12, 2023 9:47 am
Can you post the text of the bug report? Your snapshot does not contain the minimal information required to analyse the problem.
Posted: Thu Jan 12, 2023 8:26 pm
by Pourya
hi Mike,
here is the text?
<CrashReport>
<Error>
<message>Segmentation fault Signal</message>
<time>2023-01-12 15:25:28.150</time>
<threads>main,layerPainter1,layerPainter2,layerPainter3,layerPainter4,layerPainter5,layerPainter6,layerPainter7,layerPainter8</threads>
<currentThread>main thread</currentThread>
<stack>---- thread main
void MaxEntryList::rejectNPeaksPerMinute(double):564
bool HistogramWidget::select(bool, QGpCoreMath::SamplingOption):111
---- thread layerPainter1
virtual void SciFigs::LayerPainterThread::run():59
---- thread layerPainter2
---- thread layerPainter3
---- thread layerPainter4
---- thread layerPainter5
---- thread layerPainter6
---- thread layerPainter7
---- thread layerPainter8
</stack>
<bugStack>---- thread main
---- thread main
</bugStack>
</Error>
<application>max2curve</application>
<version> Qt 5.12.3
QGpCoreTools 2.4.2 from 3.4.2
(commit 33d7a93616e30a3d511fa67ad3f5da9da1a4aac6)
QGpCoreMath 1.4.2 from 3.4.2
(commit 306e3c199829ace6cbde6b242503355428580d05)
QGpCoreWave 2.2.0 from 3.4.2
(commit 18e08f9fd358a9e504047ec288ca4ab71a7c9851)
QGpGuiTools 2.4.2 from 3.4.2
(commit 478ff49d6d6ec28d92b21ec9bfcef9f5d343b065)
SciFigs 3.3.2 from 3.4.2
(commit cec1d051784e8ee1d9774230fb96c1bb0b618aa0)
QGpGuiMath 1.3.1 from 3.4.2
(commit 8e80e068f4f3b16a30e8fb8dff21177f25a58da6)
QGpGuiWave 1.2.1 from 3.4.2
(commit 2889d6a23de9671c33c0ae088b33e537035df26f)
max2curve 1.1.2 from 3.4.2
(commit 4ebfd70dad6fa2bb44f6e28898ecc68bfdd87357)
GeopsyCore 4.4.2 from 3.4.2
(commit 583bacf54d7367d6c29796a28c8179b98d88e28a)
geopsyfigs 1.0.2 from 3.4.2
(commit 33697385e465d0d0ec4344aba55058811e934918)
</version>
<system>windows 10</system>
</CrashReport>
