Multiple Instances of Dispersion Curve Computation-Problem
Posted: Wed Aug 05, 2015 5:10 am
I am trying to use dispersion curve computation tools (call dispersion_curve_init, call dispersion_curve_rayleigh) in a parallel (multiple instances) Fortran 90 code. Before this, I managed to compile and succesfuly run the example - main.f without issues on a single core
However, once I compile and run the multi-core one, I get the following warning "Only one instance of Application or ApplicationCore is allowed", and the program crashes.
Is there a way to overcome this? Any suggestion is welcome.
