dinver crashes when higher mode is selected
Posted: Wed Dec 10, 2014 5:36 am
by agorbatov
I tried to include first higher mode into inversion but dinver plainly crashes with segmentation fault. I tried one target with autocorrelation curve set with both mode selected and two different targets where every mode selected separately. In both cases it doesnt work. Any clue?
Re: dinver crashes when higher mode is selected
Posted: Tue Apr 26, 2016 7:58 pm
I guess that it is now too late to investigate this problem. However if you are still facing the same issue, can you copy the crash report here? The facility to collect crash reports has been buggy for while now. I should repair it.
Posted: Tue Jun 14, 2016 4:56 pm
by Morphiner
Just today I tried to do the same. Autocorrelation curves with 1st higher mode and got a crash.
The report:
<CrashReport>
<Error>
<message>Segmentation fault Signal</message>
<time>2016-06-14 12:53:34.138</time>
<threads>main,layerPainter1,layerPainter2,layerPainter3,layerPainter4,layerPainter5,layerPainter6,layerPainter7,layerPainter8,run_01,,run_02,,run_03,,run_04,,run_05,,,,,,,,</threads>
<currentThread>main thread</currentThread>
<stack>---- thread main
---- thread layerPainter1
virtual void SciFigs::LayerPainterThread::run():59
---- thread layerPainter2
---- thread layerPainter3
---- thread layerPainter4
---- thread layerPainter5
---- thread layerPainter6
---- thread layerPainter7
---- thread layerPainter8
---- thread run_01
---- thread
---- thread run_02
---- thread
---- thread run_03
---- thread
---- thread run_04
---- thread
---- thread run_05
bool DinverCore::Neighborhood::random(int, int):398
virtual void InversionThread::run():217
---- thread
---- thread
---- thread
---- thread
---- thread
---- thread
double QGpCoreTools::StatValue::misfit(int&, int&, const QGpCoreTools::Value&, QGpCoreTools::StatValue::MisfitType, double) const:154
double QGpCoreWave::ModalCurve::misfit(int&, int&, const QGpCoreWave::ModalFactory&, QGpCoreTools::StatValue::MisfitType, double) const:158
double DinverDCCore::TargetList::curveMisfit(const QList<QGpCoreWave::ModalCurve>&, QGpCoreWave::ModalFactory&, const DinverDCCore::Target&, int):435
void DinverDCCore::TargetList::surfaceMisfit(double&, double&, QGpCoreWave::LayeredModel*, int, bool&):292
double DinverDCCore::TargetList::misfit(int, bool&):259
virtual double Forward::misfit(bool&):62
bool DinverCore::AbstractForward::monteCarlo():267
---- thread
---- thread
</stack>
<bugStack>---- thread main
---- thread run_01
---- thread
---- thread run_02
---- thread
---- thread run_03
---- thread
---- thread run_04
---- thread
---- thread run_05
---- thread
---- thread
---- thread
---- thread
---- thread
---- thread
---- thread
---- thread
---- thread main
---- thread run_01
---- thread
---- thread run_02
---- thread
---- thread run_03
---- thread
---- thread run_04
---- thread
---- thread run_05
---- thread
---- thread
---- thread
---- thread
---- thread
---- thread
---- thread
---- thread
</bugStack>
</Error>
<application>dinver</application>
<version> Qt 4.6.3
QGpCoreTools 1.23.0 from geopsypack-2.5.0
(built on 201212060929)
DinverCore 0.9.4 from geopsypack-2.5.0
QGpGuiTools 1.13.2 from geopsypack-2.5.0
(built on 201201301054)
SciFigs 2.6.4 from geopsypack-2.5.0
dinver 0.5.4 from geopsypack-2.5.0
(built on 201206291117)
GeopsyCore 3.5.0 from geopsypack-2.5.0
GeopsyGui 2.11.0 from geopsypack-2.5.0
QGpCoreWave 1.1.0 from geopsypack-2.5.0
QGpCompatibility 0.3.1 from geopsypack-2.5.0
(built on 201103131942)
DinverDCCore 1.7.0 from geopsypack-2.5.0
QGpGuiWave 0.6.1 from geopsypack-2.5.0
(built on 201102011717)
DinverDCGui 0.2.0 from geopsypack-2.5.0
DinverGui 0.2.1 from geopsypack-2.5.0
dinverdc 1.4.1 from geopsypack-2.5.0
(built on 201102011728)
</version>
<system>Windows 7</system>
</CrashReport>
