Geopsy 3.2.0 crash w/ 3 component files
LilianaO
Post by LilianaO »
Good morning,
I'm a Ph.D. student at the University of Lisbon, working with Paula Teves Costa, and I'm using and testing Geopsy.
I tested the latest version of Geopsy with the ready-to-go database file available to download at http://www.geopsy.org/wiki/index.php/FK. When I what to use the 3 component files with the FK toolbox, the program crash, and I can't process the data.
At the same time, I can't define the source distance in the active experiments when I customize the properties in Table.
I will appreciate the answer and some more explanations.
Thank you.
Liliana Oliveira
Re: Geopsy 3.2.0 crash w/ 3 component files
Hi Liliana,
Version 3.3.1 is now available. Did you try with this new version? Does it still crash?
LilianaO
Post by LilianaO »
Good night Marc,
I try with the 3.3.2 version and it still crashes.
When I test with the parameters of the tutorial I obtain the attached message.
I don't understand what it can be.
Thank you.
Liliana Oliveira
(45.22 KiB) Not downloaded yet
Hi Liliana,
Did you try high resolution FK (RTBF) for 3 components or conventional FK? With 3.3.3, only the last one crashes. 3.3.4-preview (accessible for Linux and Mac when compiling from git repository) fixes everything. 3.3.4 will be soon available also for Windows.
