Saving temporary files
agorbatov
Postby agorbatov » Mon May 05, 2014 5:38 am
I am trying to save results of correlation (waveform option). After processing there is "processed" group that can be seen as temporary file and crosscorrelation can be seen on waveform visualization window. I use preference settings to set where to save the database. I save the file and Log does say that geopsy is saving. Processed group becomes permanent file. After saving the database and exiting from geopsy I run geopsy again and try to load the resulting processed database. Although there is the database file after loading there is nothing, just empty names. What is wrong in my steps? Thank you, Alex
Return to “Geopsy usage”
Users browsing this forum: Bing [Bot] and 1 guest
